Ir para o conteúdo principal
Alldaymall A88X LCD Screen Replacement
O que você precisa
  1. Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: passo 1, imagem 1 %32 Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: passo 1, imagem 2 %32 Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: passo 1, imagem 3 %32
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
    Pergunte ao FixBot
    Comentar
  2. Alldaymall A88X LCD Screen Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
    Pergunte ao FixBot
    Comentar
  3. Alldaymall A88X LCD Screen Replacement, Speaker: passo 3, imagem 1 %32 Alldaymall A88X LCD Screen Replacement, Speaker: passo 3, imagem 2 %32 Alldaymall A88X LCD Screen Replacement, Speaker: passo 3, imagem 3 %32
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
    Pergunte ao FixBot
    Comentar
  4. Alldaymall A88X LCD Screen Replacement: passo 4, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 4, imagem 2 %32 Alldaymall A88X LCD Screen Replacement: passo 4, imagem 3 %32
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Alldaymall A88X LCD Screen Replacement: passo 5, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 5, imagem 2 %32 Alldaymall A88X LCD Screen Replacement: passo 5, imagem 3 %32
    • Desolder the speaker wires from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Alldaymall A88X LCD Screen Replacement, Camera: passo 6, imagem 1 %32 Alldaymall A88X LCD Screen Replacement, Camera: passo 6, imagem 2 %32 Alldaymall A88X LCD Screen Replacement, Camera: passo 6, imagem 3 %32
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
    Pergunte ao FixBot
    Comentar
  7. Alldaymall A88X LCD Screen Replacement: passo 7, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 7, imagem 2 %32
    • Desolder the wires that connect the battery to the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Alldaymall A88X LCD Screen Replacement: passo 8, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 8, imagem 2 %32
    • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Alldaymall A88X LCD Screen Replacement: passo 9, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 9, imagem 2 %32 Alldaymall A88X LCD Screen Replacement: passo 9, imagem 3 %32
    • Using a pair of tweezers begin to peel the antenna from the metal panel.
    • Work your way down until the antenna is completely removed.
    • Be careful not deform the antenna or sever its connection.
    Pergunte ao FixBot
    Comentar
  10. Alldaymall A88X LCD Screen Replacement: passo 10, imagem 1 %32
    • Using a pair of tweezers remove the tape securing the cameras to the back panel.
    Pergunte ao FixBot
    Comentar
  11. Alldaymall A88X LCD Screen Replacement: passo 11, imagem 1 %32
    • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
    Pergunte ao FixBot
    Comentar
  12. Alldaymall A88X LCD Screen Replacement: passo 12, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 12, imagem 2 %32
    • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
    Pergunte ao FixBot
    Comentar
  13. Alldaymall A88X LCD Screen Replacement, Motherboard: passo 13, imagem 1 %32 Alldaymall A88X LCD Screen Replacement, Motherboard: passo 13, imagem 2 %32 Alldaymall A88X LCD Screen Replacement, Motherboard: passo 13, imagem 3 %32
    • Use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
    • Using a pair of tweezers remove the ribbon cable from its receptacle.
    Pergunte ao FixBot
    Comentar
  14. Alldaymall A88X LCD Screen Replacement: passo 14, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 14, imagem 2 %32 Alldaymall A88X LCD Screen Replacement: passo 14, imagem 3 %32
    • Now on the left ribbon cable use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
    Pergunte ao FixBot
    Comentar
  15. Alldaymall A88X LCD Screen Replacement: passo 15, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 15, imagem 2 %32
    • Desolder the wires that connect the backlight to the motherboard.
    Pergunte ao FixBot
    Comentar
  16. Alldaymall A88X LCD Screen Replacement: passo 16, imagem 1 %32 Alldaymall A88X LCD Screen Replacement: passo 16, imagem 2 %32 Alldaymall A88X LCD Screen Replacement: passo 16, imagem 3 %32
    • Using a PH0 screw bit unscrew the three 3mm screws securing the motherboard to the back panel.
    Pergunte ao FixBot
    Comentar
  17. Alldaymall A88X LCD Screen Replacement: passo 17, imagem 1 %32
    • Carefully lift up on the motherboard from its housing.
    Pergunte ao FixBot
    Comentar
  18. Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: passo 18, imagem 1 %32 Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: passo 18, imagem 2 %32 Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: passo 18, imagem 3 %32
    • Gently pry the brackets holding the touch sensor to the LCD Screen
    • Do not bend the touch sensor to much as it may shatter.
    Pergunte ao FixBot
    Comentar
  19. Alldaymall A88X LCD Screen Replacement, LCD Screen: passo 19, imagem 1 %32 Alldaymall A88X LCD Screen Replacement, LCD Screen: passo 19, imagem 2 %32
    • Set the touch sensor aside.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Drhaber
Membro desde: 02/10/16
985 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 4-1, Lacy Spring 2016 Membro de USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 1,710
