Introdução
The side buttons on the Alienware AW610M are responsible for providing short-cuts and in-game actions. After some time, the side buttons may stop working due to wear or build up of debris. Replacing the side buttons allows the mouse to be reliable and work at its best ability.
Before you start replacing the side buttons, make sure the mouse is turned off and unplugged. If you are unsure about the side button being the source of the problem, refer back to our troubleshooting page before you continue.
O que você precisa
Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
Detach the cable connector, and remove the scroll wheel.
Gently detach the last connector using your fingers.
