Ir para o conteúdo principal
Alienware AW610M Mouse Feet Replacement
O que você precisa
  1. Alienware AW610M Mouse Feet Replacement, Mouse Feet: passo 1, imagem 1 %32 Alienware AW610M Mouse Feet Replacement, Mouse Feet: passo 1, imagem 2 %32 Alienware AW610M Mouse Feet Replacement, Mouse Feet: passo 1, imagem 3 %32
    • Power off the mouse and disconnect any wired connections.
    Pergunte ao FixBot
    Comentar
  2. Alienware AW610M Mouse Feet Replacement: passo 2, imagem 1 %32 Alienware AW610M Mouse Feet Replacement: passo 2, imagem 2 %32
    • Use a spudger to gently lift and remove the old mouse feet.
    • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
    • Be careful not to scratch the mouse surface or damage the plastic housing.
    Pergunte ao FixBot
    Comentar
  3. Alienware AW610M Mouse Feet Replacement: passo 3, imagem 1 %32 Alienware AW610M Mouse Feet Replacement: passo 3, imagem 2 %32
    • Take a lint free cloth lightly dampened and clean away any remaining adhesive residue.
    • Allow the surface to dry completely before applying new feet to ensure proper adhesion.
    Pergunte ao FixBot
    Comentar
  4. Alienware AW610M Mouse Feet Replacement: passo 4, imagem 1 %32 Alienware AW610M Mouse Feet Replacement: passo 4, imagem 2 %32 Alienware AW610M Mouse Feet Replacement: passo 4, imagem 3 %32
    • Peel the adhesive backing off the new mouse feet. Align the mouse foot with its designated area on the mouse. Press firmly to secure it in place. Repeat steps for bottom mouse foot.
    • Make sure the feet are properly aligned before pressing, as misalignment can affect mouse performance.
    Pergunte ao FixBot
    Comentar
  5. Alienware AW610M Mouse Feet Replacement: passo 5, imagem 1 %32 Alienware AW610M Mouse Feet Replacement: passo 5, imagem 2 %32 Alienware AW610M Mouse Feet Replacement: passo 5, imagem 3 %32
    • Power the mouse back on via wired or wireless connection and test the glide and tracking on a smooth surface.
    • If the mouse still tracks poorly, check the surface or sensor for dust or debris.
    Pergunte ao FixBot
    Comentar
Conclusão
Ashley S.
Membro desde: 09/24/25
171 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 46-4, Johansen Fall 2025 Membro de Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 61
Ao todo: 270
