Ir para o conteúdo principal
Alienware AW610M Motherboard Replacement
O que você precisa
  1. Alienware AW610M Motherboard Replacement, Battery: passo 1, imagem 1 %32 Alienware AW610M Motherboard Replacement, Battery: passo 1, imagem 2 %32 Alienware AW610M Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Power off the mouse and disconnect any wired connections.
    Pergunte ao FixBot
    Comentar
  2. Alienware AW610M Motherboard Replacement: passo 2, imagem 1 %32 Alienware AW610M Motherboard Replacement: passo 2, imagem 2 %32
    • Use a spudger to gently lift and remove the old mouse feet.
    • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
    • Be careful not to scratch the mouse surface or damage the plastic housing.
    Pergunte ao FixBot
    Comentar
  3. Alienware AW610M Motherboard Replacement: passo 3, imagem 1 %32 Alienware AW610M Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Alienware AW610M Motherboard Replacement: passo 4, imagem 1 %32 Alienware AW610M Motherboard Replacement: passo 4, imagem 2 %32
    • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
    • Don't pull the halves completely apart, as internal wires still connect them.
    Pergunte ao FixBot
    Comentar
  5. Alienware AW610M Motherboard Replacement: passo 5, imagem 1 %32 Alienware AW610M Motherboard Replacement: passo 5, imagem 2 %32 Alienware AW610M Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the battery pack inside the mouse.
    • If you are having trouble, use a small flat tool to help ease it out.
    • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
    Pergunte ao FixBot
    Comentar
  6. Alienware AW610M Motherboard Replacement: passo 6, imagem 1 %32 Alienware AW610M Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
    • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
    Pergunte ao FixBot
    Comentar
  7. Alienware AW610M Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Alienware AW610M Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
    • Detach the cable connector, and remove the scroll wheel.
    • Gently detach the last connector using your fingers.
    • Be careful when unplugging all connectors to prevent tearing them.
    Pergunte ao FixBot
    Comentar
  8. Alienware AW610M Motherboard Replacement: passo 8, imagem 1 %32 Alienware AW610M Motherboard Replacement: passo 8, imagem 2 %32
    • Detach the blue ribbon that connects the motherboard to the shell casing.
    • Using a Phillips #1 screw driver, remove two 5.4 mm screws to detach the motherboard from the base shell casing.
    Pergunte ao FixBot
    Comentar
  9. Alienware AW610M Motherboard Replacement: passo 9, imagem 1 %32 Alienware AW610M Motherboard Replacement: passo 9, imagem 2 %32 Alienware AW610M Motherboard Replacement: passo 9, imagem 3 %32
    • Gently detach the motherboard using your fingers.
    Pergunte ao FixBot
    Comentar
Conclusão
Sherlyn Herman
Membro desde: 09/24/25
97 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 46-4, Johansen Fall 2025 Membro de Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 49
Ao todo: 311
