Ir para o conteúdo principal
Acer Chromebook CB3-532-C47C Battery Replacement
O que você precisa
  1. Acer Chromebook CB3-532-C47C Battery Replacement, Back Panel: passo 1, imagem 1 %32 Acer Chromebook CB3-532-C47C Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Battery Replacement: passo 2, imagem 1 %32 Acer Chromebook CB3-532-C47C Battery Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Battery Replacement, Remove the battery cable: passo 3, imagem 1 %32
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Battery Replacement, Battery: passo 4, imagem 1 %32 Acer Chromebook CB3-532-C47C Battery Replacement, Battery: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery from the laptop.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 outras pessoas executaram este guia.
Sadie Brown
Membro desde: 10/25/21
967 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Duração total: 1,429
