Ir para o conteúdo principal
Accessing Logicboard
O que você precisa
    1. Accessing Logicboard, Front and Back Cover: passo 1, imagem 1 %32 Accessing Logicboard, Front and Back Cover: passo 1, imagem 2 %32
      • Remove the following screws:
      • Two silver 3.15mm Phillips #00 screws on the right side of the camera
      • Two silver 2.08mm Phillips #00 screws on the left side of the camera
      Pergunte ao FixBot
      Comentar
    2. Accessing Logicboard: passo 2, imagem 1 %32
      • Remove the two indicated screws on the bottom of the camera:
      • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
      • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
      Pergunte ao FixBot
      Comentar
    3. Accessing Logicboard: passo 3, imagem 1 %32 Accessing Logicboard: passo 3, imagem 2 %32
      • Carefully pull the back of casing away from the front.
      Pergunte ao FixBot
      Comentar
    4. Accessing Logicboard: passo 4, imagem 1 %32 Accessing Logicboard: passo 4, imagem 2 %32 Accessing Logicboard: passo 4, imagem 3 %32
      • After removing the back cover, several things must be removed.
      • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
      Pergunte ao FixBot
      Comentar
    5. Accessing Logicboard: passo 5, imagem 1 %32 Accessing Logicboard: passo 5, imagem 2 %32
      • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
      Pergunte ao FixBot
      Comentar
    1. Accessing Logicboard, Logicboard: passo 6, imagem 1 %32 Accessing Logicboard, Logicboard: passo 6, imagem 2 %32
      • On the front of the camera, in battery case, remove screws indicated:
      • Two black 2.05mm Phillips #00 screws
      Pergunte ao FixBot
      Comentar
    2. Accessing Logicboard: passo 7, imagem 1 %32 Accessing Logicboard: passo 7, imagem 2 %32
      • Flip the camera over to the backside and remove screws indicated:
      • The screw circled in red is a longer black 3.00mm Phillips #00 screw
      • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
      Pergunte ao FixBot
      Comentar
    3. Accessing Logicboard: passo 8, imagem 1 %32
      • Pull the cover plate off for the two power cord jacks.
      Pergunte ao FixBot
      Comentar
    4. Accessing Logicboard: passo 9, imagem 1 %32 Accessing Logicboard: passo 9, imagem 2 %32 Accessing Logicboard: passo 9, imagem 3 %32
      • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
      Pergunte ao FixBot
      Comentar
    5. Accessing Logicboard: passo 10, imagem 1 %32
      • Remove the orange tape on top of the SD cardholder.
      Pergunte ao FixBot
      Comentar
    6. Accessing Logicboard: passo 11, imagem 1 %32
      • Open the battery cover.
      Pergunte ao FixBot
      Comentar
    7. Accessing Logicboard: passo 12, imagem 1 %32 Accessing Logicboard: passo 12, imagem 2 %32
      • Lift the indicated plastic piece off.
      Pergunte ao FixBot
      Comentar
    8. Accessing Logicboard: passo 13, imagem 1 %32 Accessing Logicboard: passo 13, imagem 2 %32
      • Remove screws indicated:
      • Two black 4.80mm Phillips #00 screws
      Pergunte ao FixBot
      Comentar
    9. Accessing Logicboard: passo 14, imagem 1 %32
      • Unsolder points indicated.
      • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
      Pergunte ao FixBot
      Comentar
    10. Accessing Logicboard: passo 15, imagem 1 %32 Accessing Logicboard: passo 15, imagem 2 %32 Accessing Logicboard: passo 15, imagem 3 %32
      • Carefully lift up SD cardholder to reveal logicboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Nicole Wong
Membro desde: 01/30/11
371 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-29, Regan Winter 2011 Membro de Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 1,980
