Ir para o conteúdo principal
AYL SoundFit Motherboard Replacement
O que você precisa
  1. AYL SoundFit Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
    Pergunte ao FixBot
    Comentar
  2. AYL SoundFit Motherboard Replacement: passo 2, imagem 1 %32
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
    Pergunte ao FixBot
    Comentar
  3. AYL SoundFit Motherboard Replacement: passo 3, imagem 1 %32
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
    Pergunte ao FixBot
    Comentar
  4. AYL SoundFit Motherboard Replacement: passo 4, imagem 1 %32 AYL SoundFit Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
    Pergunte ao FixBot
    Comentar
  5. AYL SoundFit Motherboard Replacement: passo 5, imagem 1 %32
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. AYL SoundFit Motherboard Replacement: passo 6, imagem 1 %32 AYL SoundFit Motherboard Replacement: passo 6, imagem 2 %32 AYL SoundFit Motherboard Replacement: passo 6, imagem 3 %32
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
john
Membro desde: 03/10/16
171 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-3, Harley Spring 2016 Membro de IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Membros
Autoria de 5 guias
3Comentários do guia
Where do u get a new motherboard at?
calvinsmith522 - Responder Compartilhar
Anybody know where to get a motherboard?
David Whitman - Responder Compartilhar
Where do I get a motherboard?
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 2,013
