Ir para o conteúdo principal
ASUS ROG Spatha X Switch Replacement
O que você precisa
  1. ASUS ROG Spatha X Switch Replacement, Mouse Cover: passo 1, imagem 1 %32 ASUS ROG Spatha X Switch Replacement, Mouse Cover: passo 1, imagem 2 %32 ASUS ROG Spatha X Switch Replacement, Mouse Cover: passo 1, imagem 3 %32
    • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
    • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
    • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
    Pergunte ao FixBot
    Comentar
  2. ASUS ROG Spatha X Switch Replacement: passo 2, imagem 1 %32 ASUS ROG Spatha X Switch Replacement: passo 2, imagem 2 %32
    • Lift the upper mouse cover up and off.
    Pergunte ao FixBot
    Comentar
  3. ASUS ROG Spatha X Switch Replacement, Switch: passo 3, imagem 1 %32 ASUS ROG Spatha X Switch Replacement, Switch: passo 3, imagem 2 %32 ASUS ROG Spatha X Switch Replacement, Switch: passo 3, imagem 3 %32
    • Remove the switch(es) you'd like to swap out by gently grabbing them on either side and pulling straight up.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
cgrabowski1
Membro desde: 03/21/25
671 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 69
Ao todo: 714
