Ir para o conteúdo principal
ASUS ROG Spatha X Battery Replacement
O que você precisa
  1. ASUS ROG Spatha X Battery Replacement, Mouse Cover: passo 1, imagem 1 %32 ASUS ROG Spatha X Battery Replacement, Mouse Cover: passo 1, imagem 2 %32 ASUS ROG Spatha X Battery Replacement, Mouse Cover: passo 1, imagem 3 %32
    • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
    • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
    • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
    Pergunte ao FixBot
    Comentar
  2. ASUS ROG Spatha X Battery Replacement: passo 2, imagem 1 %32 ASUS ROG Spatha X Battery Replacement: passo 2, imagem 2 %32
    • Lift the upper mouse cover up and off.
    Pergunte ao FixBot
    Comentar
  3. ASUS ROG Spatha X Battery Replacement, Battery: passo 3, imagem 1 %32 ASUS ROG Spatha X Battery Replacement, Battery: passo 3, imagem 2 %32 ASUS ROG Spatha X Battery Replacement, Battery: passo 3, imagem 3 %32
    • Grip the white battery connector and pull it up and out of its motherboard socket.
    Pergunte ao FixBot
    Comentar
  4. ASUS ROG Spatha X Battery Replacement: passo 4, imagem 1 %32 ASUS ROG Spatha X Battery Replacement: passo 4, imagem 2 %32
    • Disconnect the side button assembly ribbon cable from the motherboard.
    • Use an opening tool to gently pry the battery up and out of the chassis.
    • Take care not to bend, twist, or puncture the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
cgrabowski1
Membro desde: 03/21/25
671 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 15
Últimos 30 dias: 79
Ao todo: 636
