Ir para o conteúdo principal
ASUS Q405U Battery Replacement
O que você precisa
  1. ASUS Q405U Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
    Pergunte ao FixBot
    Comentar
  2. ASUS Q405U Battery Replacement: passo 2, imagem 1 %32
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
    Pergunte ao FixBot
    Comentar
  3. ASUS Q405U Battery Replacement: passo 3, imagem 1 %32 ASUS Q405U Battery Replacement: passo 3, imagem 2 %32 ASUS Q405U Battery Replacement: passo 3, imagem 3 %32
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
    Pergunte ao FixBot
    Comentar
  4. ASUS Q405U Battery Replacement: passo 4, imagem 1 %32 ASUS Q405U Battery Replacement: passo 4, imagem 2 %32
    • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
    • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
    • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
    Pergunte ao FixBot
    Comentar
  5. ASUS Q405U Battery Replacement, Battery: passo 5, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
    Pergunte ao FixBot
    Comentar
  6. ASUS Q405U Battery Replacement: passo 6, imagem 1 %32
    • Once all screws are removed, lift the battery out from the base of the computer.
    Pergunte ao FixBot
    Comentar
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Equipe
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 2-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G8
4 Membros
Autoria de 5 guias
1Comentário do guia
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 49
Ao todo: 2,753
