Ir para o conteúdo principal
APEX TM785CH Speakers Replacement
O que você precisa
    1. APEX TM785CH Speakers Replacement, Back Casing: passo 1, imagem 1 %32 APEX TM785CH Speakers Replacement, Back Casing: passo 1, imagem 2 %32
      • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
      • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
      • Move along the top edge of the tablet and repeat the step above.
      • Pull the back cover away from the tablet body to completely remove it.
      Pergunte ao FixBot
      Comentar
    1. APEX TM785CH Speakers Replacement, Speakers: passo 2, imagem 1 %32 APEX TM785CH Speakers Replacement, Speakers: passo 2, imagem 2 %32 APEX TM785CH Speakers Replacement, Speakers: passo 2, imagem 3 %32
      • The speakers are located towards the bottom left and bottom right corners of the tablet.
      • If not already done, remove the black tape holding the wires down.
      • Wedge a spudger underneath the speaker in its socket, near where the wires are connected. You can then pry out the speakers.
      Pergunte ao FixBot
      Comentar
    2. APEX TM785CH Speakers Replacement: passo 3, imagem 1 %32 APEX TM785CH Speakers Replacement: passo 3, imagem 2 %32
      • You will need a soldering/desoldering kit to desolder the 4 leads where the speakers connect to the circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Baylor, Team 4-1, Williams Spring 2015 Membro de Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 26
Ao todo: 2,930
