Ir para o conteúdo principal
8BitDo Ultimate Wireless Button Conductive Pad Replacement
O que você precisa
  1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: passo 1, imagem 1 %32 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: passo 1, imagem 2 %32
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Pergunte ao FixBot
    Comentar
  2. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 2, imagem 1 %32 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 2, imagem 2 %32
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Pergunte ao FixBot
    Comentar
  3. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 3, imagem 1 %32 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 3, imagem 2 %32 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 3, imagem 3 %32
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Pergunte ao FixBot
    Comentar
  4. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 4, imagem 1 %32 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 4, imagem 2 %32 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 4, imagem 3 %32
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: passo 5, imagem 1 %32 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: passo 5, imagem 2 %32
    • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell.
    • Lift the PCB out.
    Pergunte ao FixBot
    Comentar
  6. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 6, imagem 1 %32 8BitDo Ultimate Wireless Button Conductive Pad Replacement: passo 6, imagem 2 %32
    • Lift button conductive pads out of the shell with your hands.
    • Replace or clean as needed.
    • If cleaning with water, make sure pads are fully dry before replacing.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
John Sweriduk
Membro desde: 04/03/26
85 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 42
Ao todo: 147
