Ir para o conteúdo principal
8BitDo SN30 Pro+ Controller Analog Sticks Replacement
O que você precisa
  1. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: passo 1, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: passo 1, imagem 2 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: passo 1, imagem 3 %32
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
    Pergunte ao FixBot
    Comentar
  2. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Trigger Buttons: passo 2, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Trigger Buttons: passo 2, imagem 2 %32
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
    Pergunte ao FixBot
    Comentar
  3. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: passo 3, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
    Pergunte ao FixBot
    Comentar
  4. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: passo 4, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: passo 4, imagem 2 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: passo 4, imagem 3 %32
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
    Pergunte ao FixBot
    Comentar
  5. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Covers: passo 5, imagem 1 %32
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
    Pergunte ao FixBot
    Comentar
  6. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: passo 6, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: passo 6, imagem 2 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: passo 6, imagem 3 %32
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
    Pergunte ao FixBot
    Comentar
  7. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Caps: passo 7, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Caps: passo 7, imagem 2 %32
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
    Pergunte ao FixBot
    Comentar
  8. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: passo 8, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: passo 8, imagem 2 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: passo 8, imagem 3 %32
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
    Pergunte ao FixBot
    Comentar
  9. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: passo 9, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: passo 9, imagem 2 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: passo 9, imagem 3 %32
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
    Pergunte ao FixBot
    Comentar
  10. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: passo 10, imagem 1 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: passo 10, imagem 2 %32 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: passo 10, imagem 3 %32
    • Flip over the rear board.
    • Using a soldering iron to desolder all the joints of the analog sticks.
    • Make sure all the solder holes are open on the circuit board.
    • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Brian W
Membro desde: 12/21/11
1.800 Reputação
Autoria de 8 guias
5Comentários do guia
Thanks for the guide! What form factor does the sn30 use for its sticks?
Joshua Randall - Responder Compartilhar
Ever figure it out? I'm wondering the same.
Peter Hindes - Responder Compartilhar
I asked 8BitDo directly and they sent me this link https://tech.alpsalpine.com/e/products/d...
Stepan Orda - Responder Compartilhar
im just trying to replace the worn out joystick wtf
JonnyRoboto - Responder Compartilhar
Great guide, thanks! I only needed to get as far as replacing the caps but was useful to know where the hidden screws and clips were ahead of time.
Liam Jackson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 46
Últimos 30 dias: 214
Ao todo: 14,403
