Ir para o conteúdo principal
4Sight 9 Charging Port Replacement
O que você precisa
    1. 4Sight 9 Charging Port Replacement, Cover: passo 1, imagem 1 %32 4Sight 9 Charging Port Replacement, Cover: passo 1, imagem 2 %32
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. 4Sight 9 Charging Port Replacement: passo 2, imagem 1 %32
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Pergunte ao FixBot
      Comentar
    3. 4Sight 9 Charging Port Replacement: passo 3, imagem 1 %32 4Sight 9 Charging Port Replacement: passo 3, imagem 2 %32
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Pergunte ao FixBot
      Comentar
    1. 4Sight 9 Charging Port Replacement, Motherboard: passo 4, imagem 1 %32
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      Pergunte ao FixBot
      Comentar
    2. 4Sight 9 Charging Port Replacement: passo 5, imagem 1 %32 4Sight 9 Charging Port Replacement: passo 5, imagem 2 %32
      • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
      • Put pressure on the connector until the clasp comes undone.
      • Gently pull up on electrical ribbon until it disconnects from circuit board.
      Pergunte ao FixBot
      Comentar
    3. 4Sight 9 Charging Port Replacement: passo 6, imagem 1 %32 4Sight 9 Charging Port Replacement: passo 6, imagem 2 %32
      • Remove the second electrical ribbon from the motherboard.
      • Use the technique for the previous ribbon.
      Pergunte ao FixBot
      Comentar
    4. 4Sight 9 Charging Port Replacement: passo 7, imagem 1 %32
      • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
      Pergunte ao FixBot
      Comentar
    5. 4Sight 9 Charging Port Replacement: passo 8, imagem 1 %32 4Sight 9 Charging Port Replacement: passo 8, imagem 2 %32
      • With fingers, grip the green Wi-Fi connector.
      • Gently pull up on connector to remove tape holding the connector in place.
      Pergunte ao FixBot
      Comentar
    6. 4Sight 9 Charging Port Replacement: passo 9, imagem 1 %32
      • Using your fingers, gently lift the motherboard.
      Pergunte ao FixBot
      Comentar
    1. 4Sight 9 Charging Port Replacement, Charging Port: passo 10, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use soldering gun and when solder is malleable, lift up on the left side of the charge port until it is not connected to the board with tweezers.
      • Charging port may be very hot due to soldering iron.
      • Repeat this step on right side of charging port.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 1,593
