Ir para o conteúdo principal
4Sight 9 Battery Replacement
O que você precisa
    1. 4Sight 9 Battery Replacement, Cover: passo 1, imagem 1 %32 4Sight 9 Battery Replacement, Cover: passo 1, imagem 2 %32
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. 4Sight 9 Battery Replacement: passo 2, imagem 1 %32
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Pergunte ao FixBot
      Comentar
    3. 4Sight 9 Battery Replacement: passo 3, imagem 1 %32 4Sight 9 Battery Replacement: passo 3, imagem 2 %32
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Pergunte ao FixBot
      Comentar
    1. 4Sight 9 Battery Replacement, Battery: passo 4, imagem 1 %32
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      Pergunte ao FixBot
      Comentar
    2. 4Sight 9 Battery Replacement: passo 5, imagem 1 %32 4Sight 9 Battery Replacement: passo 5, imagem 2 %32
      • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
      • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
      • Repeat previous actions until battery comes loose from device.
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 2,226
