Ir para o conteúdo principal
2012-2015 Honda Civic Key Battery Replacement
O que você precisa
  1. 2012-2015 Honda Civic Key Battery Replacement, Unscrew battery cover: passo 1, imagem 1 %32 2012-2015 Honda Civic Key Battery Replacement, Unscrew battery cover: passo 1, imagem 2 %32
    • Lay the key down so that the Honda symbol is facing upward.
    • Use a Phillips #0 screwdriver to remove one screw.
  2. 2012-2015 Honda Civic Key Battery Replacement, Pry the cover off: passo 2, imagem 1 %32 2012-2015 Honda Civic Key Battery Replacement, Pry the cover off: passo 2, imagem 2 %32
    • Insert the flat end of your spudger into the notch in the side of the key/remote.
    • Pry the key remote apart to remove the cover.
  3. 2012-2015 Honda Civic Key Battery Replacement, Replace the battery: passo 3, imagem 1 %32
    • Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
    • Remove the battery.
    • Your key may contain either a CR1616 or CR1620 battery. In some cases, either type will work, but for the best results, replace it with the same kind of battery that originally came with your key.
    • Install your matching new battery in the same orientation as the original.
  4. 2012-2015 Honda Civic Key Battery Replacement, Reassembly: passo 4, imagem 1 %32
    • Place the two halves of the remote cover back together.
    • Press the unlock or lock buttons to make sure the remote is working.
    • Place the screw into the hole and tighten with a Phillips #0 screwdriver.
    I have replaced the battery correctly and the remote still does not work…Is it possible that they key died?
    joshoua-tree - Responder
    I just went through this on 2016 Civic with a fob just like the one pictured here.
    Close the doors, and make sure they are unlocked.
    Turn the key to turn the car on, but don't start it. The dash lights should come on, but don't engage the starter. Press and hold the "lock" button on the fob for one second.
    Turn the car off.
    Do that two more times. (Turn the key, hold the "lock" button for one second)
    Now, one more time. On this fourth time, leave the key turned and the dash lights lit. It will reprogram your fob when you press the "lock" button that fourth time. You have another 10 seconds to program any additional fobs by simply hitting the "lock" button for one second. So, if you have more than one, you need to do it as well.
    You only have 5 seconds on the first 3 steps between the time you turn the key and hold the "lock" button. It took me a few goes to get the first one to reprogram. Then it took a second go round to get both of them programmed.
    Edit: Additional: You can only have 3 active fobs at any given time.
    DJ AJ -
    Mine would only work if I had the negative side of battery facing up
    tjm339 - Responder
    thanks, same for me. negative side up.
    Karl Forner - Responder
    You intricately explain all the obvious steps to this process, and then completely gloss over/are vague about the one part that everyone came here to figure out— how TF does the new battery go in?? It is not intuitive.
    Meh - Responder
Conclusão
19 outras pessoas executaram este guia.
monica
Membro desde: 03/22/15
441 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 5-7, Williams Spring 2015 Membro de Baylor, Team 5-7, Williams Spring 2015
BU-WILLIAMS-S15S5G7
4 Membros
Autoria de 10 guias
27 comentários
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Harry - Responder
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert - Responder
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Arlen Kerbaugh - Responder
Thank you very helpful!!!
inakwana waka -
my 2012 remote doesn't look like this, nor does it have the same battery. it takes CR1616, and once you open the casiing, it has a second casing that needs to be opened.
Keegan Starr - Responder
I had to replace CAR battery and now, while the key works, the 5-button fob from HONDA doesn’t. Does anyone know the code of key presses for it?
el flesh - Responder
Perfect job, good steps and photos.  However some 2013 Accords  do not have a Phillips screw,  instead you move the tiny spring loaded button on the side to release the metal key,  pull it out,  then look for a fortified slot inside and turn a butter knife to open-split the case, go carefully.  NOTE- some of the 2032 batteries have a safety sticker on one face, “do not swallow”  you must remove it for the battery to work at all..  Happy Honda!
albert torizzo - Responder
Doesn’t it have to be a Panasonic brand battery for it to work? I have the exact battery shown in picture mine takes a CR1620, I bought one from walmart but key pad still doesn’t work, help please!!! Honda wants to charge me $125 just to look at it to see what’s going on!!
tmbennett11 - Responder
If you have the right type of battery, brand should not matter at all. Make sure the metal battery contacts are all clean and making good contact with the battery. Try a second replacement battery if available, in case the first one was a dud. If none of that helps, you likely have some other issue that can’t be fixed with a battery.
Jeff Suovanen -
I am having a surreal issue where I’m swapping 1620’s between two fobs. Both will work only when the battery reads between 3.0 & 3.19. I have new 1620’s and 1616’s that read 3.20 to 3.32 and old ones that are below 3.0. Doesn’t matter which fob I put them in: either one will only work between 3.00 & 3.19V. (Crazy)
P Tx -
Figured out what the issue with some batts reading high voltage but not working: I switched to the amp meter and the ones that were too low and too high volts only read .02A or less. Weird to see batteries reading 3.3V with negligible current. First time getting scammed like this with cells that show full (unloaded) voltage.
P Tx -
I have a 2015 Honda Civic. My key battery is CR 1620.
CD Malcolm - Responder
Amazing instructions. Very easy to follow. I am having Honda Accord Sport 2014, which takes CR1620 3V battery. Did the job perfectly !
Prajwal Muralidhara - Responder
Why does it show a CR1620 battery being removed?
md_medic_1977 - Responder
I changed the battery on my 2014 civic thinking it would fixe my problems but it didn’t. Me key still won’t work.
Jairo a - Responder
Good directions and photos. Exactly matched my remote fob which goes to a 2016 Civic.
For others who have different key fobs, these directions and battery types would likely not apply.
Also, for those who are still having trouble:
1) double check the battery is installed with the right + / - position being up or down. It is possible the new battery is dead. I always recommend buying 2 at a time since the cost is so low for replacements.
2) make sure when you take the existing dead battery out that you put it far away from you so you don’t mix it up with your new battery. I have done that one before which is a silly avoidable mistake.
Jim Myers - Responder
Alright guys, I am pretty sure its my alternator...but I thought i would toss a post up on here to get some feedback.
Last night I went to get gas and the car started up just fine. After I filled up, I got back in my car and turned the key. Nothing happened....the dash lit up, but it wouldnt turn over. I could hear a clicking noise but it was faint.
Called my father in law, he came and gave me a jump. Car started right up, so we I went home. Knowing that maybe it might be the battery, and i might need another jump I went to back my car into my parking space and it cut off as I was backing up.
I pulled my wifes car over and gave myself a jump again. I sat in the car and let it idle for about 15 minutes, but I had to keep revving the engine a little because it wanted to shut down.
Car has 95k on it, its the original battery and alternator. Considering it has occasionally been slow to start, I think its time to replace the battery as wellhttps://snaptube.cam/ , https://syncnet.onl/telegram-web/
spencer audrey - Responder
Hi, which battery would be equivalent to fit a 2014 Honda CR V? The Energizer 2025 or 2032 or just the CR1620? Please advise? Thanks
Mia Levy - Responder
We lost just the screw. Do you guys know when to find one?
Thanks
JC Bonassin - Responder
googled: 2015 honda civic fob battery, this entry: 2012-2015 Honda Civic Key Battery Replacement came up top.
Ordered from Amazon right away without checking. The recommended battery CR1616 is NOT the right one AT ALL. It requires CR2032.
ifix_screw_u - Responder
install new battery 2015 hona civic now cannot unlock door only half function work any idee why thanks
ti-toine65 - Responder
I’ve changed the battery, and all that fun stuff and nothing is working. My original one died only 2 yrs after I had it. This one finally gave up the ghost. I will be going to my Honda dealership on Monday.
Angela Gannon - Responder
Thanks for the detailed instructions
AlGorFun - Responder
I can't get the screw to turn any ideas
Mark - Responder
Hi there, I replaced my battery but the key isn’t responding. Is there another way to fix it if the plate that holds the battery is somehow faulty? Thanks!
Bre - Responder
Changed battery ok need to reprogram key fob
Maria Harbuck - Responder
Comentar
Visualizações:
Últimas 24 horas: 53
Últimos 7 dias: 351
Últimos 30 dias: 2,067
Ao todo: 384,220
