Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
How to reduce 8+ gigabytes of yellow "other" in the capacity?
It's taking up a precious 8.8 of my 32 gigs. I have tried restoring (from a backup) to no avail. Restoring as a new phone would result in losing years worth of text message history. Please help! Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Nathan, the storage capacity is probably at 8.8GB because of the stuff that you have on there for years. If you want to free up the memory, you have to move the stuff of your phone and onto a something more permanent. There is no way to free anything up if you do not move it off the phone. Time for some house cleaning :) Commercial software is available for doing this, like this one or you can try the trial version from here. Hope this helps, good luck
Esta resposta foi útil?
Pontuação 2
If the text messages are important to you, you should consider getting software that can copy them to your computer. After you do that, you can restore as new.
Pontuação 1
Go to the apps store and buy an app called sms export - downloads all your text msgs. needed my texts as evidence in court and i used it.
Pontuação 0
Adicionar a sua resposta
Nathan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 4,216
