Ir para o conteúdo principal
How do I get my screen to work?
I bought a new LCD screen for my Dell Studio laptop because the current screen didn't work. Now the new one doesn't work as well. There must be a connection issue that's preventing the screen from working and I don't know what it is.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Abe, it may not have been your LCD. I would check the inverter. It is the inverter that produces the high voltage that makes the tube glow. It is possible to check the inverter with a multimeter, just remember that is does supply a high voltage, somewhere around 500-700V. It is not to expensive and you can find a service manual that would work for your laptop right here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Abe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 511
