will not go past loading screen.
hi ive got an acer d260 net book. i got it from a friend that passed. im having some big problems with it. question 1, the bottom of it was taken off wrong and the shiny metal foil is torn and some small pieces are missing, would this have some thing to do with my second problem. question 2, when i turn it on it goes to the acer screen then goes to a loading screen that says,
intel undi , pxe-2.1(build 082
copyright (c) 1997-2000 intel corporation
for atheros pcie ethernet controler v2.0.0.9(05/08/09
check cable connection!
pxe-mof : exiting intel pxe rom.
no bootable device -- insert boot disk and press any key
i dont have any disks for it all i have is the net book the charger and the dvd rom drive. is it broke or is there some thing i can do like flash the bios.
Esta é uma boa pergunta?
7 comentários
Have you checked BIOS to make sure your hard drive is listed first in boot order. Do you have any other external drives plugged in? USB Stick, External HDD ect...
por Dradeel
i went in the boot manager and it says 1 option network boot: atheros boot agent. nothing plugged in to it. when i go in to f2 my boot order is as follows 1 usb hdd : 2 networkboot:atheros boot agent 3 ide0: 4 ide1 :5 usb fdd:6 usb cdrom: .
por doug
i noticed some thing else when i put amemory card in my hdd light comes on.is that an indicator that my hard drive is bad.
por doug
It does most certainly sound like you are missing your operating system. It is not necessarily a bad hard drive, for now I really think you should try and start it with a bootdisk of some sort and see what you get. Check on here http://www.bootdisk.com/bootdisk.htm and see if you might be up to try and create your own bootdisk. Let us know if you need help with it
por oldturkey03
before i do that would you know why the speaker is really low. i have the volume on the netbook up the whole way and the sound on the videos is up too?
por doug
Exibir mais 2 comentários
