Ir para o conteúdo principal
Is the touch sensor located in the digitizer?
Hi i recently replaced my ipod touch 2nd generation screen since it was broken. I replaced the screen with a new one and the left side of the ipod touch(1,4,7 number area) does not respond to touch. i noticed when i took off the screen to retry that there was a rip in the ribbon cable. is my problem then in the rip in the cable, or in the lcd part of the ipod. my main question is is the touch sensor part of the digitizer or the lcd? and if i buy a new digitizer and be more careful could this solve my dead spot problem?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Cory Sullivan, if you have a ripped cable that comes from the digitizer, and your digitizer does not work right, replace it. I am certain that this is what causes your problem. Your digitizer is the touch sensor, it sends the signals to an IC, if that IC would be a malfunction, I am certain none of your touch would work. Start with the obvious and replace what is known to be faulty.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Cory Sullivan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 911
