Ir para o conteúdo principal
Um hub residencial com tela de 7" e base de alto-falante opcional, lançado em 2026 pela Apple Inc.
Facial Recognition initial Setup Error - Possible Hardware Defect?
Right out of the box during initial set up after the voice recognition when the unit goes to set up facial recognition, I receive an error that it says it's unable to set up facial recognition, and I can choose to try again or reset the device. No matter how many recent attempts, plugging in to a MacBook Pro, etc.
Even taking to the genius bar, which does not have a diagnostic tool yet we cannot proceed past facial recognition set up. They said this is reminiscent to camera hardware errors in the iPhone that during manufacturing the camera doesn't work. The software will not let it proceed past fatal recognition set up. But they did not have a clear answer. This was ordered the second orders went live and now a replacement unit is two months away as a developer. This is really tough to swallow.
Anyone else face this issue? Anyone have any suggestions on if this is software error or actually hardware manufacturing defect that installs the software?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
It sound like a hardware issue to be honest, because you cannot even configure Facial recognition from the start. But, I’m not entirely sure. I also cannot find wide spread issues regarding this.
Since you still have warranty, I recommend to get yourself a replacement HomeView. Real bummer that it takes two months..
I don’t think it is software related, so I’m afraid this is the right thing to do..
Sorry for the bad news. It’s a great device though, but unfortunately this can occur :(..
Esta resposta foi útil?
Pontuação 2
4 comentários:
Yes, it's time to get a replacement! It's not uncommon for the first system's have a higher rate of failure. Pack it up like it was and go back to the Apple Store.
por Compartilhar
How long does it usually take for Apple to roll out diagnostic tools to their store for new hardware? The Genius Bar rep had no idea when they would even be able to plug it in to run a systems check. This seems odd for an entire new product line, but I guess that inline with how opaque they have been about that software the HomeView is even running. This all seem like an Holiday Gift go-to-market strategy more than a thoughtful new product line launch.
por Compartilhar
@garrettchr80292 - It depends on the product. That won't help you here, You aren't planning on fixing this while it's still under a few days old! Just get a replacement, don't wait to long as you'll likely get lost in the shuffle if you do.
Remember this is a North American product only from what I understand so if you took it out of country that could explain why it's not working correctly as the countries IP address won't be within the States or Canada.
por Compartilhar
Correct! It’s an NA product only. Good one! That could be the cause as well. Thank you
por Compartilhar
Adicionar a sua resposta
Garrett Christine Nelson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 45
Últimos 30 dias: 45
Ao todo: 45
