Ir para o conteúdo principal
Guias de reparo e informações de desmontagem para o novo modelo básico de MacBook Pro de 14 polegadas, lançado em novembro de 2023, atualizado com o SoC M3 projetado pela Apple. Sucessor do MacBook Pro de 13 polegadas com Touch Bar e chip M2.
Display blurred and black
Imagem
Apple logo and loading bar blur like when the room in dark . External display working fine . I re installed macOS and restarted multiple times . How to resolve this ? Is it backlight hardware issue ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Did you install any new software onto your system? The graphics engine which drives the display does offer a blur function which might be active here.
If the blur changes as the image changes. It does appear the back light is working at least where we can see an image. And as you are able to see an image on the external display I think it's safe to say the display unit has failed. I've not seen this exact effect but it could have been cause by the display getting physically damaged.
Here's the guide to replace it Substituição da tela do MacBook Pro 14" final de 2023 (M3)
Esta resposta foi útil?
Pontuação 0
2 comentários:
is it backlight have any fuse or something ?, in mother board ?, acutely it happened in low battery time I plug the power cable.
por Compartilhar
@eldogeorge - Are you trying to tell me the blur is a reflection? Do you have a matte cover glass on the screen?
Yes, there is a fuse. But it rarely blows unless there's a short in the logic. Did you have a liquid spill into the system? If you did that's going to need to be cleaned up.
por Compartilhar
Adicionar a sua resposta
Eldo George será eternamente grato(a).
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 35
Últimos 30 dias: 35
Ao todo: 35
