Ir para o conteúdo principal
A segunda geração de tablets Samsung Galaxy Tab com tela de 7,0 polegadas. Números de modelo: GT-P3105, GT-P3100 e GT-P3105.
Storage change from tablet to tablet
I have a tab 2.7.0 which is smashed quite badly, even corners etc and won't turn on. I now have a 2nd hand one that works fine. I am wondering if I can change the harddrive with all my stuff stored on there, from the broken one to the newer one, as if nothing ever happened to the old one.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
In many tablets and smartphones, the storage is provided by flash memory chips that are soldered directly onto the motherboard, instead of using a separate hard drive.
Replacing those flash memory chips is an extremely difficult repair, so replacing the entire motherboard is usually much easier.
If you can remove the motherboard from the damaged tablet and it has not been physically damaged, you might want to try swapping it into the replacement device.
iFixit has a motherboard replacement guide here:
Samsung Galaxy Tab 2 7.0 Motherboard Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kevin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 36
Ao todo: 36
