Ir para o conteúdo principal
Modelo A1181: processador Core 2 Duo de 1,83; 2; 2,1; 2,13; 2,16; 2,2 ou 2,4 GHz
Desktop picture gets distorted
Whenever i touch the track pad of my MacBook13" (A1181) the desktop picture acts weird. It gets distorted and that happens only when i touch it, when i don't, it looks fine. Ive uploaded two states of that distortion. Any idea what it might be?
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This looks more like a LCD screen failure. The display is set up like fabric with a set of Lines that run horizontally as well as vertically. As the upper is present and we see banding in the lower section of the image has lost its horizontal sync.
Other than replacing the display assembly Substituição do display do MacBook Core 2 Duo is the only way to fix this. As the display has micro cracks which has severed some of the signal lines.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
genik será eternamente grato(a).
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 26
Últimos 30 dias: 26
Ao todo: 26
