How to Replace The Keypad.
The Keypads broken and i have a casing of Nokia 5310 XpressMusic
Esta é uma boa pergunta?
The keypad design for both the 5310 and 5310b is completely identical, so you can easily replace it using your 5310 casing.
Here is the step-by-step guide for the replacement:
Substituição do teclado do Nokia 5310b XpressMusic(Note: As mentioned in Step 3 of the guide, some models require you to remove the screws from the back before lifting the faceplate, so please double-check your device first!)
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 16
Ao todo: 16
