Ir para o conteúdo principal
Guias de reparo e informações de resolução de problemas para fornos de micro-ondas.
Micro wave not heating up
Can you repair a micro wave
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@roberthousden No, because the "I" in iFixit means YOU! We teach you how to fix your stuff.
Now, what is the Microwave that we are working with? Make and model? We need some information here before we throw out a answer to you.
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
The short answer here is that yes, a microwave oven can be repaired in most cases.
As Theo already stated, we can't do anything without knowing which microwave you have, as repair and troubleshooting procedures will vary widely among different models and manufacturers.
Failing to heat can be caused by any number of problems, so diagnostic steps would need to be taken to determine what failed. Are you comfortable using a multimeter? Can you safely discharge the high voltage capacitor inside the oven? Are you knowledgeable about safety procedures for high voltage circuits?
If you answered no to any of these questions, you'll be better off taking it to a repair shop than trying to work on it yourself. There are potentially lethal voltages present inside so precautions must be taken in order to safely work on it.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Robert Housden será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 32
