How to remove trigger assembly
How to remove covers so as not to break
Esta é uma boa pergunta?
Did you review the Guides section (tab next to Answers, upper right screen) for exploded diagrams and documents?
FixBot's comments (beware of Ai errors):
I couldn't find a step-by-step repair guide for removing the trigger assembly on the Bosch 4310 in the iFixit knowledge base, but I found relevant repair information elsewhere on the web.
Safety First: Always unplug the miter saw from the power source before servicing any electrical components or opening the handle housing.
To access and remove the trigger assembly:
Reassembly is performed in reverse order 1.
Sources:
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 68
Ao todo: 68
1 comentário
Identify the exact device/model first, then use its service manual to locate hidden screws and clips; release clips gently with a plastic pry tool to avoid breaking the covers.
por arshjot Compartilhar
