Ir para o conteúdo principal
Lançado em julho de 2018, o MacBook Pro de 15", modelo A1990, possui uma tela de 15,4 polegadas com retroiluminação LED e tecnologia True Tone, TouchID e processador Core i9 de até 6 núcleos.
Unresponsive TouchID/power button (compatibility issues)
Dear All,
I browsed through the previous questions and it is my understanding that the touchID button in the MacBook Pro 15" is paired with the logic board.
In our case the button is unresponsive both for the ID and for turning on and off the machine. The click is audible and working.
Assuming the piece had a torn connection and we did not need the touchID function, could we substitute the button alone, without need of the whole, "twinned" touchID+logic board?
Thank you in advance for the help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You still face the fact the data on the drive won't be accessible with a different button.
But given your symptoms I'm not sure that's the issue here. Do you have access to a DVM? So you can check the power rails.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Teru.0s será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 15
Ao todo: 15
