Ir para o conteúdo principal
A Samsung anunciou a linha Galaxy Flip5 durante o evento "Unpacked" em 26 de julho de 2023. A nova série de smartwatches Galaxy Watch 6 e os tablets Galaxy Tab S9 também foram anunciados.
Is it possible to replace flex cable without complete disassembly
So I bought a secondhand Zflip5 for about 60$ and everything except the flex cable connecting the two halves works fine. When I fold the phone it cuts the power and the slightest movement would cause this to happen. Pretty positive that the flex cable is broken as hooking up a temporary cable outside the hinge fixed this. However, judging from the repair videos i found, to replace this cable you first have to completely disassemble everything including the screen, hinge, and the motherboard, and I highly suspect I'll mess up and damage the screen, which is now worth more than the whole device in where I live.
Has anyone successfully replaced the flex cable without tearing down the whole device or might know what I can try? thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
never mind I gave up and tore it apart, dunno whether the screen survived yet but judging by the fact that the flex cable is held down by screws and metal plates id say it is not possible to replace it without removing the screen or disassembling everything.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Leooooo1061 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 26
Últimos 30 dias: 50
Ao todo: 50
