Ir para o conteúdo principal
O OP-1 field é o sintetizador aprimorado da teenage engineering, sucessor do seu OP-1.
OP-1 Keyboard replacement availability
When will the OP-1 keyboard be availble? It has been out of stock for a while now and I need one as I have an important button that doesnt work and I need a replacement keyboard.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I am not asking about a whole keyboard but the sparepart you sell for the OP-1. When will your sparepart be available?
por Compartilhar
Adicionar um comentário
2 respostas
here is a used one = https://reverb.com/p/teenage-engineering...?
Esta resposta foi útil?
Pontuação 0
Unfortunately, TE doesn't seem to have any replacement keyboards available, even if you contact them directly, so I wouldn't expect iFixit to restock them either.
As alternatives, you could try a community-made DIY keyboard replacement called Choccy Mod (you can find it on Etsy), or modify the firmware to remap the broken key to another key.
Pontuação 0
Adicionar a sua resposta
Viktor Steinarsson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 108
Ao todo: 137
