Ir para o conteúdo principal
Informações de reparo, desmontagem e solução de problemas para o iPhone 15, lançado em 22 de setembro de 2023. Ele vem com uma tela OLED de 6,1", um sistema de câmera dual de 48 MP e USB-C.
Snapped back flex cable
While removing the back glass of the iphone 15, I forgot about the flex cable, moved the back glass up, and snapped the flex cable connecting the back glass and the phone.
Imagem
Is my only option here to purchase a wireless charging assembly? Or can I get the flex cable alone?
Imagem de Replace a damaged or malfunctioning internal inductive charging coil in an iPhone 15.
Produto
iPhone 15 Wireless Charging Antenna Assembly
$20.99
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Actually, yes, you can get just the flex cable if you're confident in your soldering skills to make four small solder joints. I'd describe myself as slightly better than average electronics soldering skills, and this is something I would attempt; in fact, I've done a similar repair on an iPhone 11 Pro.
Here's one flex cable I located; there may be more if you continue to search on a phrase like "iphone 15 flex cable for wireless charging replacement".
1Pcs Wireless Charging NFC Coil Flash Flex Cable For iPhone 15 16 Plus 16 15 Pro Max Charger Panel Sticker WPC Pad Tape Parts - AliExpress 509
However, if cost is a factor, the full coil plus cable is only about $1 USD more than the cable alone. If it was me, the main consideration would be whether I wanted to go to the work of removing and replacing the charging coil; it looks like the new coil I linked to does contain the magnets.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tamaam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 28
Ao todo: 28
