Ir para o conteúdo principal
How to replace the screen?
Reason why I am asking is because my aunts dog jumped on her tablet and cracked the screen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The Tab S10 FE 5G is definitely repairable, but the screen replacement is a fairly involved job. Samsung’s service manual says the screen is heavily adhered and specifically calls for a large suction cup and heat to separate it, with extra care around the battery and internal components.
I’d first confirm whether only the glass is cracked or whether the display and touch are also affected. If the LCD and touch still work normally, you still generally replace the complete screen assembly rather than trying to separate the glass yourself. The basic process is to heat the adhesive, carefully lift the screen, disconnect its flex cable, clean the old adhesive, connect and test the replacement, then install new adhesive and press the screen back into place. Samsung specifically recommends testing the assembly before fully sealing it.
The big warning is the battery. Don’t push a pry tool deeply into the tablet while separating the screen, and don’t use excessive heat. With a cracked screen, Samsung also recommends taping over the broken glass and wearing eye and cut protection before starting.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Casey Teska será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 29
Últimos 30 dias: 164
Ao todo: 239
