Ir para o conteúdo principal
O Mercedes-Benz W126 é uma série de automóveis da Classe S fabricada pela Mercedes-Benz entre 1979 e 1992. Estreando em setembro de 1979 como sucessora da linha W116, a W126 foi a segunda geração a ostentar oficialmente essa prestigiosa designação, uma abreviação do termo alemão Sonderklasse ou "classe especial". O W126 foi oferecido inicialmente com motores de seis cilindros em linha, V8 e um motor a diesel turboalimentado para o sedã. Uma versão cupê de 2 portas C126 foi introduzida em setembro de 1981.
auto trans dip stick
I have an 84 merc 300sd. I can't get the locking cap on the trans dip stick to release so I can pull the dip stick.. I think it has a missing or broken part. I think there is supposed to be a lever that releases it. I just got the car so I'm not sure what the problem is. The cap will rotate and will pull up slightly but won't come out. Can I force it ? If so how? If I break it in the process of removing it, do you know where I can get a replacement? Thanks for your advise.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
On an ’84 300SD, I wouldn’t force it yet. There is supposed to be a locking lever on that cap. The black piece underneath the red cap swings up and releases the clamp around the dipstick tube. Once that lever is released, the cap and dipstick should come out.
If that little lever is missing or broken, that may be exactly why you’re stuck. I’d look closely underneath the cap and see if there’s a small black hinged piece you can get a finger under. Don’t put a pair of pliers on the cap and start twisting it yet; it’s old plastic and you’ll probably just make the job more expensive.
There are replacement locking caps available, and Mercedes owners have been replacing these for years.
One other thing: once you get it out, check the end of the dipstick. These old Mercedes sticks can have the rounded end broken off, which can make the level markings misleading.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Where can I get a replacement? The only one I've found is in the UK and very expensive to ship. Where can i get one in the USA?
por
Adicionar a sua resposta
tom campbell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 27
Ao todo: 38
