Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para os controles Joy-Con 2 do Nintendo Switch 2.
ZL Button Spring not working
I am trying to reassemble the left Joycon 2, and when I want to attach the ZL button, it feels like the spring is not doing its work. The ZL button is really steady and almost rubbing the button, so with a little touch it will press it.
Imagem
Imagem
Update (09/28/26)
Hello,
I was changing the covers. At the end I found the issue. The flex was not seating well on the support. From the top it looked like it was in the support, but I saw it sideways and it was not. This is why the ZL button was almost touching the button.
Imagem
Imagem
Thank you for reaching out!
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi!
Glad that you figured it out :)! Have a great day!
por Compartilhar
Thank you! I was about to just accept I busted my controller until I found this.
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Please follow this to step 13: Substituição do joystick do Joy-Con 2 (esquerdo)
Could you show us how the spring look like?
What is the reason you opened it? Is another shell used or is this a cover that you have put on?
I know that some shells do not fit completely and could cause this as well.
Thanks!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
David Sandoval Galiana será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 31
Últimos 30 dias: 118
Ao todo: 191
