O Jeep Cherokee KL, produzido entre os anos-modelo 2014 e 2023, marcou uma mudança controversa para o nome ao transitar de uma plataforma tradicional de tração traseira (RWD) para uma arquitetura transversal de tração dianteira (FWD) compartilhada com a Alfa Romeo.
Navegue neste tópico para encontrar o local apropriado para este comentário. Em seguida, clique em “Anexar comentário a esta postagem” para movê-lo.
1 comentário:
Year, engine size, maintenance history? EFI systems are mostly electronics with wiring everywhere so replacing parts may overlook wiring damage from wear and tear, chafing, modifications, etc. Did you perform continuity tests on each suspect wire to eliminate one damaged wire that can stop signals between accelerator and ecm? Ecm to throttle connections. Wiring diagrams may be available if you're familiar with wiring, testing, understand basic EFI systems, etc. As you may or may not know, both pedal and throttle have dual(?) feedback sensors so the ecm can monitor and control throttle. Dual feedback is for safety against a runaway engine controlled by electronics. We're driving on throttle by wire systems; all electronics, no steel cables between pedal and throttle plate. Electronic pedal and servo motor controlling throttle plate opening/closing. The ecm does all the work.
por F Dryer
