Ir para o conteúdo principal
A1708/EMC 3164 — Lançado em junho de 2017, este MacBook Pro de entrada mantém as teclas de função tradicionais (em vez da Touch Bar OLED).
Keyboard damage - one key
Hi guys,
One of my laptop keys came off. I had considered buying the key caps but it appears the part needed to hold the key caps is also broken off.
What do I need in this case? Please see attached photos. I can send some more of required.
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Ouch! This doesn't look good.
There's more damage than the keycap parts here! The clips are fully gone as well as the switch pieces. I don't see anyway to fix this without just replacing the full keyboard.
A good Mac tech can do this, it's not an easy repair, you might want to look at a used 2019 or newer system as the 2016 to 2018 models have had issues with their Butterfly keyboards. The 2019 have better keys.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Eric Njogu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 71
