Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para o smartwatch Google Pixel Watch 4, lançado em outubro de 2025. Disponível nos tamanhos de 41 mm e 45 mm.
Screen replacement, found spring
I completed disassembly and was about to start reassembly with the new screen when I noticed a very small spring.
The spring was just sitting there magnetically attached to the watch internals, and unclear where it came from.
If anyone has any idea where it should go, please let me know
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Looks like there are springs under the two "structural guides" (not sure what else to call them) on opposite sides of the watch.
They also tie into the screws inside the watch band grooves. Each has two springs, one of mine came out.
No idea how to get the spring back in without potentially causing more damage, so I left it out and things seem to be working fine.
Here is a picture pointing out the spring locations...
Imagem
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brian Hastings será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 69
Ao todo: 155
