Ir para o conteúdo principal
O OnePlus 15 é um smartphone topo de linha lançado em 2025. O smartphone possui um chip Snapdragon 8 Elite de 5ª geração, um chip de Wi-Fi G2 que permite Wi-Fi 7, uma bateria de grande capacidade e câmeras equipadas com o DetailMax Engine.
Why my phone display lining
My phone is 10 lines on the display and it is still increasing and one liner changes colour red and other lines are green
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Lines on the display indicate damage to the signals between the motherboard and the OLED display. Usually it's due to disruptions between the flex cable and the glass the LED circuits are printed on. Unfortunately, that kind of damage isn't repairable, so the only fix is to replace the screen. The recommended method for your phone is to purchase the screen already mounted on the midframe; replacement is basically a process of removing all the internal components from the original phone and transferring them to the new screen+frame assembly. Since iFixit doesn't have a guide to this repair yet, this video will step you through the process.
OnePlus 15 Broken Display Repair 🔧 - Original Screen Replacement Cost & Process - YouTube
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Aryan Negi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 28
Últimos 30 dias: 54
Ao todo: 54
