Ir para o conteúdo principal
A soldagem é um método de conectar duas peças de metal, derretendo um metal de preenchimento entre elas. Existem muitos tipos de soldagem, mas este artigo foi criado para ensinar a você o básico da soldagem eletrônica.
Attach camera to microscope
I am using an Amscope microscope for soldering. I would like to attach a Nikon Z mount camera to it. What solutions have worked for folks? Thank you!
Update (09/03/26)
The microscope is an Amscope SM-4T
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You'll need a 30mm tube that fits into the microscope camera port with the needed mount. I got my microscope with the video camera with a C mount.. Contact Amscope for the needed tube or try Edmond Scientific
Esta resposta foi útil?
Pontuação 0
3 comentários:
Thank you Dan. I will have a look at Edmond. There is also a place called Microscope World that may have a solution. The ID of the port is 23mm with an OD of 25mm. You have headed me in the right direction and I will make some phone calls.
por Compartilhar
@b53evans - Why are you using the eyepiece not the third camera port? I haven't seen the need to use the eyepiece when you have a binocular microscope. Doesn't this model offer it? The lookup I did implied it did.
por Compartilhar
DanJ, you are correct. The measurements above are the camera port. I believe I have found a solution that will attach to the Z8 lens attachment ring and then drop into the camera port (https://www.microscopeworld.com/microsco...). I will order it and update this thread. Thanks for the push toward a solution.
por Compartilhar
Adicionar a sua resposta
b53evans será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 22
Ao todo: 92
