Ir para o conteúdo principal
O Samsung Galaxy A22 5G é um smartphone Android intermediário desenvolvido e fabricado pela Samsung Electronics como parte da série Galaxy A. O celular foi lançado pela primeira vez em 24 de junho de 2021. O celular vem com um sistema de câmera traseira tripla e um display eletrônico de 90 Hz. A bateria tem 5000 mAh, o que é 62 % maior que a bateria do iPhone 13 Pro.
My phone is in a bootloop
The phone keeps turning on and off. I've tried multiple times but it will not get into recovery. I have used a cable for the attemps i made. What happens at startup is a fraction of a second the samsung logo comes in and than a black screen then it goes back to the samsung logo and stays there for a few seconds and then continues on to the samsung galaxy screen powerd by android. I think the battery is severly uderpowerd as it has been laying for a while, but even still without any power to the phone from any power source it does still keep restarting. I was able to access the download menu, but I do not want to lose any information on the phone.
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
@yuribraad Go ahead and try to find the right battery for your phone. If you already assume that the problem is the battery, why don't you do it? Get some tools out, and get to carefully prying it open.
por
Hi , i hope you are well . i have the same problem , did you find a solution ?
por
Adicionar um comentário
1 resposta
this is what Chrome AI has to say about the question
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Yuri Braad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 35
Ao todo: 59
