Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Pixel 6 do Google, lançado em outubro de 2021. Identificado pelos números de modelo GB7N6 e G9S9B16.
Fingerprint setting not available
There's no fingerprint option in settings
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Thanks for reaching out. The description is a bit sparse for a single diagnosis, so a few details would help: Was the display recently replaced? Is this a managed/work phone? And which Android build is installed (Settings > About phone)?
For low-risk steps, try restarting the phone, then check for and install any pending system updates. Confirm the expected path: Settings > Security & privacy > Device unlock > Fingerprint & face unlock. You can also test in Safe Mode (press and hold power, then tap and hold Restart) to see if the option appears. If the phone has a work profile or device policy, biometrics may be hidden by an administrator.
If the display was replaced, the under-display sensor may need Google's official Pixel fingerprint calibration workflow, and a non-compatible display can prevent enrollment. Back up your data before any reset, but don't factory reset as a first step—it may not fix a hardware mismatch.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Raiyan Habib será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 43
Ao todo: 118
