Ir para o conteúdo principal
O headset de realidade mista Meta Quest 3 foi lançado em 10 de outubro de 2023 e é o sucessor direto do Meta Quest 2 e, em muitos aspectos, o sucessor espiritual do Meta Quest Pro.
Update and restart loop
I have bought this device used, so I have no warranty.
The device keeps updating and restarting, side load update didn't work because the site said incompatible device or something like that, and factory reset didn't work either (it reseted and still had the loop).
Is there some different manual way to fix that, maybe somehow completely wiping the quest 3's SSD and manually installing the OS?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
It sound like firmware/NAND issues.
It would be very difficult to fix this.
I would check with Meta their support to see what options you have.
Anyway, if you would like to know more about it's NAND, you can follow this: Identificação dos chips do Meta Quest 3
Hopefully Meta does have a solution for you or maybe you can sent it in, so that they can refurb it.
Sorry for the bad news.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Aleksandr Muchin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 16
Ao todo: 60
