Ir para o conteúdo principal
Currently lost of power
No power I don't know what happen it directly lost power since my last used
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@jundeewong Do you mean that the toaster itself doesn't have power, or does your whole house not have power? If your toaster does not have any power, then I suggest opening it up and changing out the PSU or power cord. If your whole house does not have power, then I would suggest that you either wait for the electricians to bring the grid back up, or change the fuses if the fuses for your home has blown.
por Compartilhar
Adicionar um comentário
1 resposta
If you didn't check you outlet ckt breaker, then my assumption would be, u can't fix it if I told you what the problem was.
However, assuming the breaker is tripped, then the issue might be a bad middle door switch or a worn mechanism.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jun Dee Wong será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 29
Ao todo: 119
