Allwinner H618 custom board
  • (BA882_141_V1.0) flashing fails at 44% with error 0x161
Body: I am trying to flash a custom Allwinner H618 Android TV box / embedded board (Model: BA882_141_V1.0 22244) from a defunct manufacturer, and I don't have the original backup firmware.
Details:
  • SoC: Allwinner H618
  • RAM Chips: 4x 4EE77 D9QBQ (batch codes vary slightly: HFB7, H8JP, HHTC)
  • Symptom: Every compatible firmware I've tried stops flashing at around 44%–45% and throws error 0x161 (Download Boot Failed). The front display doesn't light up, and only the optical port LED stays on.
  • What I've tried: Tested multiple generic firmwares matching the hardware, but they all fail at the bootloader/DRAM initialization stage due to missing custom boot parameters.
Is there a known workaround, or a way to build/modify a compatible bootloader or DRAM configuration to bypass this error without the original factory
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
