Ir para o conteúdo principal
Drain pump stopped working.
Model GTW 460ASJ5WW I had repair guy tell me our drain pump was bad.I think he came up with the code 16.I replaced the pump and now the drum won’t fill water.Lid lock keeps tripping.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Nothing is working. No answer from you.
por
@richardpri32195 Just as a heads up for the future, we aren't a AI or a Search Engine, we are real people that use up our free time to help others. It takes time for us to figure out the correct solution! Nothing is immediate! You could try to ask our repair bot, FixBot, about this problem, or just wait.
por
Adicionar um comentário
1 resposta
Hello,
Did you replace the water pump? Or the drain pump? Try to do a calibration for it if possible!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Richard Principio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 31
Ao todo: 70
