How can I take the back off
i already took off all the screws to the back but it seems a bit hard to take off should i just brute force it?
Esta é uma boa pergunta?
Hi!
Brute force is not the recommended option! The lower case is secured by hidden latches, that you preferably use a suction cup and opening pick to remove.
Lenovo has official guides on how to disassemble and replace most parts of your laptop, which you can find in the Hardware Maintenance Manual, see page 27 for how to remove the lower case (i.e. chassis/ the back).
Your laptop only has visible screws (seven screws of different lengths!), then the lower case is secured by hidden latches that you have to unsnap.
For reattaching the lower case, you simply put the lower case back, then press along the sides and in the middle to secure the latches again.
For a visual demonstration you can follow this iFixit guide with clearer steps, the iFixit guide is for another model but judging from the Hardware Maintenance Manual the steps are pretty much identical.
Feel free to ask further questions, or if you want any clarifications.
Good luck,
Cheers
Esta resposta foi útil?
Hello,
NO, you should probably NOT brute force the bottom panel off! Listen to @alberteinst6187's comment and look for hidden screws!
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 120
Ao todo: 120
1 comentário
Do you mean the bottom? Did you check under the feet to see if there were any screws?
por Albert Einstein
