Front Radar sensor errors
My front Radar sensor is giving my errors, I cannot use my cruise control. How can I fix this issue
Esta é uma boa pergunta?
I had the same problem with my 2022 CR-V hybrid sport touring model. It happens mostly in rain or foggy conditions. More than likely it has to do with the camera above rear view mirror. With the placement behind the windshield in its own sealed enclosure, it tends to fog up, blocking the view, fooling the system into thinking you’re in a low visibility situation. It’s a design issue which was addressed in later models, such as my 2026. There is no permanent fix, but running your defogger on high when you first start out, to warm up the windshield may help.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 37
Ao todo: 111
@ericgibson86652 Year? That would help us A LOT. And can you give us the error codes?
por Theo Grefalda
