Ir para o conteúdo principal
Model M8541 / 5 or 10 GB hard drive / scroll wheel physically turns
My iPod is not recognized by iTunes or the desktop?
My 10GB iPod Classic is not recognized by iTunes or the desktop. Tried everything including resetting. When I connect to my computer, all it does is make a clicking sound. Could it be the hard drive? If so where would I get a new one?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
lindsym, if all you get is the rhythmic clicking, it does sound like the hard drive. You should get a message to contact Apple etc. on the display, but I would go ahead and replace the drive anyway :-) Just a quick warning, the HDD are not inexpensive. Check on here and I am sure you can find more places like it. Follow this guide for the repair. Also, you might want to consider replacing the HDD with a CF card. Check this answer for more information. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 0
I definately agree. I use a stethescope to listen to the ipod and
compare the sound against a known good ipod. Like oldturkey
says....rhythmic clicking is a bad drive because there is only
1 moving part in any ipod....the drive platters and read/write heads.
Normally, you can hear the platters spin...sounds like a whine.
You can tell it's a spinning thing from the sound it makes.
So if the sound is different - toast it is.
Pontuação 0
Adicionar a sua resposta
lindsym será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 692
