Ir para o conteúdo principal
My switch lite wont recognize button presses
So i just did a full shell mod and screen replacement on my switch lite and ever since I have these problems with the buttons,thumbsticks, and touchscreen not registering my presses and movements I replaced the ribbon cable to the right daughter board thinking it was the problem and I have seated and reseated all of the ribbon cables, put two different pairs of joysticks. And its really hit and miss as to when it does it but it wont let me do multiple presses making it to where I cant unlock my device. Does anyone have any ideas what I should do I have all the electronics repair tools needed to fix most things
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Could be a lot of things. Since you have replaced the screen, it could be that the touchscreen was damaged and not registering your input. I would check that one out and also the ribbon cable, in the worst case, you need to replace it for a new one.
I know that there are some really bad shells out there, so it's possible that the shell squished something on the motherboard or broke ribbon cables. Can you let us know which brand you are using? Or is it something from AliExpress?
Are all the buttons stopped working? If yes, it could be motherboard related...
In my opinion, I would transfer it back to the old shell and test again to see if that will work. OR if it's too damaged, buy a broken/donor Switch Lite and get the shell from that one.
Adding pictures could help us > Adicionar imagens a uma pergunta já existente
Thanks in advance!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Andrew Derosa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 45
