Better GPU for future proofing
I know this might seem stupid but I want to build a PC on AM5 that will last me till 2032, and while I will be able to upgrade a CPU down the line I won't be able to upgrade a GPU till that 2032 mark and I want a GPU that will last till then playing games I don't care if it won't be able to handle everything on Ultra by then but I also won't wanna be playing everything on Low then, not because my GPU isn't good enough but because of vram if it means worse performance now but better later because I'll have more vram then I'm sold, I want a 1440p at least 60fps build even with the use of dlss and maybe frame gen, so if a 5060 TI by then will be able to play games with higher settings even though it is weaker but because it has more vram then I'll buy the 5060ti, but if the 5060ti will bottleneck because of performance way before the 12gb of the 5070 will become a bigger issue than the performance of the 5060 ti even though it has more vram then I'll buy the 5070, please I need good information and a lot of help because I don't know about future proofing a lot, thanks! (Also recommendations about other GPUs are welcome but if it's and AMD please list how fsr compares to dlss because if it really isn't a big difference which I hear it is then ok and also I want rt or path tracing but not max and no older NVIDIA graphic cards 50 series only)
Esta é uma boa pergunta?
Hi!
We at iFixit are a hardware and components repair group and not as much for these kind of questions.
A better place to start at would be:
- Somewhere at Reddit, e.g.
- - r/PCMasterRace: https://www.reddit.com/r/pcmasterrace/
- - r/PcBuild: https://www.reddit.com/r/PcBuild/
- The LTT Forum: https://linustechtips.com/
- The Tom's Hardware Forum: https://forums.tomshardware.com/
Otherwise they are probably better equipped to point your in the right direction.
Good luck with your build!
Cheers
por MeekVixen
Hi!
This is a repair site, not a consumer site! You can ask this question on social media platforms like Reddit.
T
por Theo Grefalda
